Anthony jaques
Does anybody here know the stock springrate on front and Rear for the fireteam This is so frustrating looking for it.
Thank you didn't even think bout that prob would have saved me 2 hrs searching lolFind the part numbers on the exploded views then look up the part. Spring rate will be part of the description.
I looked it up and it says they are 72 mm I don't understand I measured them by hand they are 95mm off the dampner wtfFind the part numbers on the exploded views then look up the part. Spring rate will be part of the description.
Fronts are 85 mm rear is 95mm fronts say 6.91lb per inch and rear is 5.54lb per inch this doesn't make senseI looked it up and it says they are 72 mm I don't understand I measured them by hand they are 95mm off the dampner wtf
What I'm trying to achieve is acceptable performance with added stainless steel chassis gaurd with no pre load?I looked it up and it says they are 72 mm I don't understand I measured them by hand they are 95mm off the dampner wtf
They also have fronts to matchFound these 5mm shaft 2mm coil me think yep
+1Trust me when I tell you this but stay with the stock shocks. I'll have to find the thread but someone posted some stiffer springs.
