michicrm
Hi All,
I have browsed through the comments and there seem to be similar issues with some users but nothing on there helped so far in my case. I am a little desperate since the car does not work right now. Maybe I start from the beginning.
I bought my vorteks a year ago and it was running just fine for the most part. I had some overheating issues but that seems to be the problem with vorteks I read. 2 weeks ago I read that this could be solved by upgrading from the factory builtin 100A ESC to the 130A Esc. I want to buy a roller in the future anyway so I decided to go for the 130A ESC and wanted to try it in the Vorteks. My first questions is: Can I do that with all other electronics being stock?
So when I connected the new ESC the red light constantly blinks and it will not take the throttle. I tried calibrating the ESC as described in the manual but it won't work. When entering calibration mode there is a constant red light with beeps which is supposed to do it. In the manual it says to leave the transmitter in neutral position and then press the set button again. Then a green light should follow when the esc takes the setting. When I press the set button the beeping stops and nothing happens (no green light). I thought that maybe the new ESC is broken. When I connected the old 100A one it behaves exactly the same way.
I also binden the receiver and the transmitter again. I also reset the transmitter and the esc to factory setting. After that, binden the whole thing again but nothing worked.
I have the bluetooth module to connect to my transmitter. Connection works and with both ESC´s I get the alarm that the ESC´s are overheated (see screenshot). It gives me the maximum temperature. Has anyone had that issue before?
Since I tried 2 ESC´s I guess they are not the issue. Can it be that it is the receiver?
Thanks already for your input. I am really lost what else I can try out.
Michael
Michael
