Just hooked it up to a stx2 and it’s still not going into the modeHave you tried a different RX? Make sure that your remote trims are all set to zero. That has messed me up before.
So when I’m holding the set button there is a not so bright red light that flashed but when I let go it goes green, this still doesn’t workTry this..
Well if you can't figure out how to factory reset or calibrate, and the receiver is good I don't know what to tell ya. YT is your best friend.So when I’m holding the set button there is a not so bright red light that flashed but when I let go it goes green, this still doesn’t work
