Joshdyrect
New Member
Hey, I just picked up a notorious and when powering it up, the steering works and reverse works but no forward throttle. I read that it may need calibration so I tried that. It goes into calibration mode, does 1 beep for neutral but when I pull the throttle and try to calibrate the second beep nothing happens. I’ve tried it 2-3 times with no luck. I’m not sure what’s supposed to be plugged into the transmitter so I took a pic. Esc is plugged into the batt/prog. Let me know if you have any ideas and thanks in advance!
