Questions get progressively more technical.
So it seems there is a problem with durability with most 5v fans so i think ive decided to go 12v route but have some q's to the people that know their stuff.
1) I don't want to spend $70 on an NFC so what actual fan is being used in this setup as id like to just order the fan and wire/mount it all up myself. I appreciate what he's done for the hobby...but its just a fan.
2) 12v fans: If i'm running one of those fans, how much mah/min (don't know if that's an actual measurement but you get what i'm asking?) will this fan use? trying to determine if its low enough to just wire into balance lead and not worry about unbalancing pack or run a separate small 3s battery.
3)(three parts) If I wire two of those fans in series (1x esc 1x motor) I can run them off full 4-6s v-bat and not have to worry about unbalancing cells correct? (if running 4s pack neither fan will be at its full working voltage which is ok?) NOW...If i were to run 2 in series (1x esc 1x motor) and then a second off the motor fan but wire it parallel off the first motor fan, the ESC fan should see 12v and each motor fan 6v ya? A) is their a way to wire so if one of the motor fans fails the remaining working fan will then receiver the full 12v that was being split with both running? B) will these fans even run off of 6v or potentially less?
