Fireteam Fireteam 6S 1/7 Upgrade shocks?
TyphoonS3
Hello where are upgraded shocks for jumping for 6S fireteam 1/7 scale.
or can I use 1/6,1/5 shocks for jumping thanks.
No need to revamp/upgrade the stock shocks AT ALL.
Stay with the 6s shocks. 1/5 shocks will not fit.
You can play with shock oils to dial them in as you please . Even convert them to TLRT Typhon specs with the TLR Machined and tapered shock pistons and lower bottom cartridge parts and X-Rings. M2C ZRS is always an option. Depends how you plan on bashing.
Can make them more plush if you want to dial them in more.
Stock 6s shocks are known to be the best for the 6s line of Arrma rigs. Shock's end's can be upgraded to Tekno's Ends and Spring perch's etc. What I do when/if the stocker rod ends break. User driver error is responsible for this however.
