It's dropped in that place ..Is it bound there or can you push it down?
No the high one. Firstly there is no load on the suspension arms and secondly, no shocks. But do they both have the same area of travel?It's dropped in that place ..
When I lift up it drops down again
The high one is bound.. I have removed suspension armsNo the high one. Firstly there is no load on the suspension arms and secondly, no shocks. But do they both have the same area of travel?
Here is a video if it helps ..Seems like something is sticking or bound..when your shocks are removed both arms should drop evenly down
Take your pins out .clean them well . reinstall and check again
On your lower control arms where the pin slides through make sure that area is also free of grease / dirt / gunk .after it's all clean and sliding pin ,lightly lube the pin . slide it back in forth into the arms until you feel no resistance..
Here Is another video ..Seems like something is sticking or bound..when your shocks are removed both arms should drop evenly down
Can you do a video of the left arm that's not dropping all the way down.you showed us the right side going up and down which is the good side ..I want to see what the tei rod and cv axel is doing .do it slow a few times then fast like lift the arm all the way up then let it drop.thanksHere is a video if it helps ..
I just changed the servo so I wonder if related ?
Thanks so much
Simon
I don't see a second vidHere Is another video ..
The hex ends don't seem even straight on both ends ?
