ActionJackson
Nice man!I bit the bullet and decided to turn my Zippkits FE33 into a speedrunner.. This boat will do 70mph oval laps all day long in its current configuration, but for speedrunning I'm going to drop in a TP 4050 2400kv and a converted XLX2, and going to run it on an SRD 6200mah 6s pack with a Dasboata prop, not sure witch one yet.. I'm not sure what to do about the turnfin, I'll probably run with it on at first and once everything is dialed in then maybe take it off and run it.. Sam Hallstrom on youtube has done 121mph with one of these same boats, with a setup not too different from what mine will be, so I know these boats can do big numbers if setup well.. Here I'm just laying out locations for esc and the battery, I left the wood battery tray out of the boat so it has a huge compartment with room to move the battery fore and aft. I use the large white foam pieces in the boatstand (and other smaller pieces of foam) to keep the pack in place tightly instead of battery straps. I'm just getting started with this build but it should be fun
I see you mention a ‘converted’ XLX2… was it a land version with a heat sink originally? If so how did you convert to run cooling tubes through it?
