Outcast Good day for a build/rebuild
HZRDOS
  1. Kraton 4s
  2. Outcast 4s
  3. Outcast EXB
  4. Talion EXB
Rainy new years day.. perfect day for a good build.
My OC 4s I built not long ago is going to a LWB chassis. I also built a monster buggy (MB I call it) not long ago which is a Krston 4s with a buggy body. I LOVE that thing for small area quick bashing. Just like the handling and jumping better than the SWB on 4s...so time to convert the OC 4s to a LWB.
Have to say I finally found the perfect slipper build for me. I use the HR aluminum plates in place of the stock slipper pads, and also added the plastic nut from the slipper maintenance kit. Running it at 3/4 turns out from stock...it is perfect. The stock slipper pads would start to slip more at about 1/2 pack each time, but would be fine next pack....so they must be heating up and slipping more. HR aluminum pads stay consistent the entire pack.
Hey buddy, Did you do a build thread on making your 4s car? Am I remembering right that you are attaching 4 or 6s arms to a 3s chassis or something (which is why are you sold off those CVDs you made…?)
Thanks man!
Thanks man!
Yeah, it is actually my build thread badge link. Since I made this into a full 4s with the arms and hubs, I am using the full 4s CVDs. But the chassis are the same as the 3s line.
I should’ve known that lol. Thanks, I’m gonna check it out. Rather inspired me.
After getting through the diff and slipper issues all figured out, have to say, these 4s rigs I built get more run time than my 6s rigs. They are light and fast.
Nice…I can see that. Best of power and light weight worlds.
I saw above what you did for the slipper, what were the diff issues you dealt with?
I have stripped a few input gears, but they were on the monster buggy I built. I have since fine tuned the slipper. That is the key, you MUST have a little bit of slip for 4s.
Otherwise it’s too much for the drivetrain to handle huh? And alloy pads keeps it from overheating while allowing the needed slip…brilliant! 😃
Yeah. They seem to provide a consistent slip (more of a 1 second chirp, not full slip rotations....which is perfect)
