TurboWillybags
I’ve just got some GPM aluminium knuckles and they don’t seem to be compatible with the rear CVD cup. I put the bearings into the knuckle, put the cup in but the hole for the pin that goes through the hex isn’t far enough past the outer bearing so I cannot get the pin through. I track the issue back to the cup touching a metal surface inside the knuckle itself, rather than the cup pushing snug up against the inside bearing race. Have others had this issue? What’s the solution - do I need GPM rear cvd and cups too?
