- ST.LOUIS
- BigRock 4x4
- Mojave
- Notorious
- Senton 6s
- Senton 3s
- Typhon 6s
17mm HR extensions an typhon arms vs stock arms
I used these turnbuckles on brcc an senton,longer threads more bite.re
What did you set your toe and camber to?Typhon 3s BLX turnbuckels arrma part #AR330542, need a total of 6, I believe they come in a 2 pack.
Typhon 3s BLX a arms, I got mine from RPM part number 80762 and 80842.
Someone posted the length of stock turnbuckles earlier in the thread (measured eye to eye)What did you set your toe and camber to?
Thank you, I'm waiting on parts to do the wide arms on my Granite. I went with RPM Typhon arms and turnbuckle. I also switched over to 17mm hexs. Thanks again.Someone posted the length of stock turnbuckles earlier in the thread (measured eye to eye)
- 82mm for front and rear camber
- 69mm for steering
P.S. While I believe these are the lengths of Typhon turnbuckles, I think the Granite comes with more camber in the rear. When I upgraded my Granite to Typhon arms, I remember setting rear camber links 2mm shorter than the front, so 80mm.
I keep on braking mine and it’s getting annoying do you recommend any titanium ones what? And what size should I get? I currently have 5225 traxxas end rods on OEM steel rod from arena and they are trashhhh!! Or should I try that 4x60?
did you use 80w on both front and rear for the shocks?Longer arm = longer suspension travel
I'm running 80w in my brcc with typhon arms
