can you put the stock spur gear on the blx slipper clutch? and what is the difference between the diffs?First of all it’s the mega slipper so you had it coming?. The blx slippers are better and I think the whole assembly is $35. And If the motor is getting hot on 17tooth and wicked fast gear down.
do you happen to have a temp gun or something similar? it will be much more helpful with a temperature reading. Keep it below 180°f and you will be good to go. I bring mine in on hot days and measure 190+ (LoL) on a 14t with the blx diffs. The mega diffs have a slightly lower gear ratio so yours will be different.
Does it make it faster? How would I put the blx slipper in it because I don’t have a 5mm shaft on the motor. And could I just buy the Blx diff outer gear and the Blx input shaft?Internal gears are the same but the ring gears on the diffs are different. The same with the input gears between the Mega and BLX.
Could you send one that would fit and would have the same speed of the 17t I have? I am new to this hobby so I don’t know that much stuffYou don’t need to change the diffs if you don’t beat the heck out of your truck (like I do) just put the hd 17t input in the back and it won’t break off. As for the pinion there are 1/8” bore options that will mesh with the blx spur gear.
i have the 48 pitchDo you know what pitch gears you have are the really tiny 48pitch or the bigger 32p. The 32p teeth are almost an 1/8 inch from tooth to tooth tip may be 1/16”.
I think he has the max10 combo and not max10 sct combo. So the motor is a 3652 with a 3mm shaftYou will need the blx slipper which only comes in one choice of teeth and the adjustable motor mount. With that max 10 combo a 15t pinion will work and will keep the heat down, it is the stock gear for the granite blx. I’m assuming your motor has the 5mm shaft so a 15t gear should be easy to find at your LHS or online.
