You put 14mm hexes on a Typhon?Ready for winter. My granphon 3s.
Just wondering, did you use Granite axles or did you find a way to put 14mm hexes on the Typhon axles?Yeah just for winter. Got tons of 14mm tires.
Cool thanks! I was aware of both ways but just wondered which way you went. Good info for others who may not know tho ??There are two ways you can do it. Buy these, and the screw on just like the diff ends. Or buy the granite drive shafts, and just slide the tire end of the shaft on and off. The second way is easier to switch out. Then you also have spare diff side too.
