pomplemus
Hello everyone!
I'm in the process of converting my M2C V4 Kraton to V5, with a new rear shock tower, sway bars, and arms.
The noodly RPM arms are just too flexy, with the drive shafts constantly popping out of the cups and drooping. I've also broken several just in the past couple weeks, so I figure if arms are consumable I may as well go to the stock arms but upgrade to V5.
As far as I know, the M2C V4 chassis should work with the new arms, I just need to grind down the droop screw ears a bit.
I messaged M2C to see to see if they have a template or something, but they responded in the negative.
For anyone that's done this, can you please share your experience and share any relevant tips? I really want to get a clean result and not remove anymore material than I have to.
A picture of the newest V5 compatible M2C chassis with a close-up on the ears would be great! Even better if it could be overlaid/ pictured next to the V4 chassis ears.
Thanks in advance!
Thanks in advance!
