- Nero
I didn’t mean to sound rude. I was just trying to save some headache. My apologies if you thought I was just brushing it off.The only differences between the V1 Outcast and the current version of the Outcast are as follows.
Larger receiver box.
Shocks with 4mm shafts and different shock mounts.
Sliding motor mount.
A couple shims in the diffs.
Slightly better stock chassis braces.
Bulkheads are little stronger.
Oh and the tower to tower brace.
I would just do some general maintenance on it like change the fluids in the diffs and shocks and change the bearings with the things I suggested above.
Larger receiver box.$10 give or take a few bucks.
Shocks with 4mm shafts and different shock mounts. Bout $75
Sliding motor mount.$20
A couple shims in the diffs. $5 shims
Slightly better stock chassis braces (Upgrade needed anyways v4 or v1)$50
Bulkheads are little stronger. $10 each (or $30 each for completed diffs inside)
tower to tower brace. $4
the biggest pain about all of this is the install time, and the shipping paid to get them to you. Most of the parts can be had from JRC. (Jenny’s rc)
now if you like wrenching on your rigs maybe this is the right path. I’ve seen it both ways, just outright replace and then sometimes repair Really up to you if you wanna put the wrench time in..
