Kraton help with steering
gman234
Manchester, England
hi everyone I am new to this and loving every minute of time when I have my kraton out and about , until I tried to change the punch setting with that stupid count the light listen to the beep setting. I think I may have done something wrong though as now the kraton pulls to the left after take of and I cant seem to get it to go straight again (it has not been crashed)any tips or help would be brilliant as like I say am just learning my way around this beast of a rc thanks.
gman234
Manchester, England
Have you checked your steering trim?
Have had a look at it and tried to adjust it but not sure what am doing lol can get it straight for about 10 yards then it starts to drift left do I just have to keep adjusting the nob a little at a time till it runs true ?
ejimbo4
North Georgia
I usually put mine on a stand and get it set to wear is close the wheels should point slightly to the outside on both sides and then I will set it down on pavement and get it moving slowly forward and finish trunking it out. If your trim knob ends up all the way one way or the other then you probably needed to recenter your servo.
gman234
Manchester, England
Thank you will have a go I have it on a stand at the moment is it a big job to recenter the servo ?
ejimbo4
North Georgia
Not at all. Remove the screw on your servo arm and take the servo arm off the servo. Power on your transmitter and then your truck (make sure your trim knob is in the neutral/Midway position) and the servo will automatically go to center. Replace the servo horn with tires pointing as straight as possible and then you can adjust the trim again to fine tune it.
gman234
Manchester, England
Thanks for you help will give it a go tomorrow and let you know the outcome cheers
gman234
Manchester, England
Nice one for the advice yesterday pal got it sorted and she is running like a dream again.
