RcSpeedFreak
Has anyone used them?
Ok it was either the Hoovo or cnhl guess I’ll go with chnl as they are around the same priceI have a handful of Hoovo batteries and they’re okay. Nothing special.
They’re one of the cheapest batteries you can buy. You get what you pay for
I plan on getting the chnl 6s 6200mah pack. Thank you for your inputYou could check these two threads and see if anyone has had that pack:
https://www.arrmaforum.com/threads/what-is-your-rc-lipo-of-choice-in-2022.49890/
https://www.arrmaforum.com/threads/what-is-your-rc-lipo-of-choice-in-2024.67716/
Overall, i've had some good experience with Hoovo, but also alot of bad experience. As already stated, they are a budget brand, so don't expect excellence and you won't be disappointed. Depends on the CNHL you're looking at, but I'd go with the CNHL's more often than hoovo's at the same price.
CNHL makes some really good batteries and also some cheap batteries.Ok it was either the Hoovo or cnhl guess I’ll go with chnl as they are around the same price
This oneCNHL makes some really good batteries and also some cheap batteries.
Which exact CNHLs are you considering?
I’m pretty sure these are the good ones I have seen raz use them in his speed runsThis one
CNHL 6200mAh 22.2V 6S Lipo Battery 90C
That’s a good one. The 70C and the 90C lines are really good. 120C is also pretty good.This one
Ok thank you for your help my zee pack is a bit wonky it was secondhand when I bought my kraton exb.That’s a good one. The 70C and the 90C lines are really good. 120C is also pretty good.
