Mojave How to keep earth out of your arrma!??(mojave)
MFM
Beast mode activated
ArrmaForum Fan
Rig of the Month Winner
New York
  2. Infraction
  3. Kraton 6s
  4. Mojave
  5. Mojave EXB
  6. Notorious
  7. Senton 6s
  8. Talion
  9. Typhon 6s
Love the tbone muds but why leave such a gap in the middle!?! Ugh. Why not use rubber(ish) in between the huge side gaps!?!? Ugh x2!
anywho, wanted to see what y’all doing out there keeping poop out of the chasis!?!? Got a rock stuck in center diff and destroyed my beautiful new HR alumi diff!! Fml.
Did a half assed clean to try and solve this on going battle of keepin her running interference free!
Here’s my first attempt. Raining on and off here today so ima go see if this works. Wish me luck. Lmk what u doing bout it ;-)
Be safe!
Don’t know why it posted doubles
Result: eh...
I used duck tape first to seal it but then went with the dusty motors cover - you can see all in my build log
they don’t make one for the Mojave yet. Or is it a universal fit?
It looks like that is working fairly well. I am going to order the tbone guards for mine as well. on top of that i will fab up something similar for the back on the truck. I feel like those back tires flick their fair share of debris into the chassis.
Also, Do you by chance have a link where i can purchase that exact motor fan setup.
https://www.amainhobbies.com/yeah-r...s-black-40.8mm-diameter-yea-ya-0261bk/p491090
https://www.amainhobbies.com/yeah-racing-30x30-aluminum-case-booster-fan-red-yea-ya-0576rd/p995587
He bought the fan mount, then the plastic fans died. Then he put on some aluminum ones.
https://www.amainhobbies.com/yeah-racing-30x30x10mm-tornado-high-speed-fan-black-yea-ya-0180/p491060
These fans also work. There is also this one from powerhobby - https://www.amazon.com/Powerhobby-Aluminum-Heat-Turbo-Speed/dp/B07ZPN9BSF The same aluminum yeah racing fans should fit on that no problem too
Worked a lot better than having nothing there! My senton and now my mojave is a tub for debris!! Keep me posted with what u come up with
These now available from Scorched Parts
Senton also:
Sorry skidmarkus just seen u asking bout my
Fan set up.
Yeah Racing YA-0576BU Aluminum Case 30mm Booster Cooling Fan Blue/Black
Yeah Racing Blue 1/8 Aluminum Motor Heat Sink W/ Dual Cooling Fans YA-0261BU
They’re very powerful!! I’ve tried several fan / heat sink set ups. Thru trial and error I’ve found these work the best.
you should definitely run a capacitor if you plan on using these w any kind of lighting or upgraded digital servo.
Fan set up.
View attachment 79555View attachment 79556View attachment 79557
what does the capacitor do?
Prevents any glitches or power robbing from everything else plugged into rx.
my senton similar set up but powered off 6s. But have upgraded steering so I run one cap for it.
