- Notorious
So, like many of you, I have been on a fan quest. Gone thru all the usual players for fans hr, hw, wtf....so on.
Well some of you may have seen my fan post about getting thicker, more powerful, NTF like fans, without the NTF price. Don't get my wrong if you got $100 to spend on fans go for it! ?
If you don't keep reading.
The problem I was facing was I got the perfect fan for $1, however was not getting the optimum performance due to it running on the 8vdc my cc bec wp 2.0 is set at. Now I could run my servo back on the internal bec & bump the cc bec to 12vdc, but that kinda defeats the reason for having a bec in the first place. And using a $50 bec to power just a single motor fan is just a waste.
What I needed was a connection directly to my balance port like Nick makes. What I didn't want to do was either tear apart a balance board for the male pins, or order $10 worth of Amazon connectors to make a single connector. What I needed was either a 4 slot servo connector or this
https://www.amazon.com/dp/B000BOXMDW/ref=cm_sw_r_cp_apa_i_.Q0hFb7Y54GMR
I happened to have an old one of these 4 pin deans connectors from way back when. Turns out the two outside pins just happen to line up with pin 1 & 4 on my balance plug. ? A little soldering, nip & file off the middle pins. Heat shrink, maybe later add some cable braiding like Nick, and now I can plug into any 3 cells of my 6S brick. So long as positive faces towards the #7 red lead, I just plug her in, and bam! A clean 12vdc source w/ not a lot of excess wiring. ?
