Kraton Hr updated there motor mount
Cereal_killer
Bash/Break/Fix/REPEAT 🤣
Hospitality Award
Missouri/Illinois
  1. Limitless
Surprised they changed the design.
Looks pretty sweet for sure. Definitely took the PPS design with the mesh adjustment screw on the side. $55 isn't bad at all either as the PPS set is like $120
I think their dual mount comes out next week 😳
Hr motor mount with mesh along with the hr aluminum top part that holds the rollbar, isn't a direct fit. You will need to drill out the holes inner more on one side only. Once then it fits perfectly.
Tips.
It makes you use AR310428. So you lose the rollbar unless you follow what I've done.
Hr motor mount with the hr aluminum top part that holds the rollbar, isn't a direct fit. You will need to drill out the holes inner more on one side only. Once then it fits perfectly.
Tips.
The Kraton one or the OC/Noto one. I mean, bizarre either way really
