Brewcity414
King of questions
Today was my first run on the mt2.8. yes they do rub a bit but sheesh I hit a curb and this was the result. This is also the tire thats been wobbling bad. Isn't this the axle arm?
Thought it was the axle that spins when the tires spinsLooks like a broken steering block.
? I was driving and from a distance my view was obstructed by a mail box.oh man that curb must have jumped right in front of you
That part and the part that spins along with the wheel. The whole unit that the hex nut is on.What? You lost me. This is the part that looks busted to me: https://www.arrma-rc.com/part/AR330469
YesAre you talking about this? https://www.arrma-rc.com/part/AR310780
Only the steering block is broken... Axle shaft looks fine... The bearing ride inside the steering block and should be fine. The axle is designed in 2 pieces to slip as the suspension articulates through its sycle over bumps and jumps.
? The way my wheel popped off yeah I know thats a 2 piece part I figured that it was broken from looking at it. Cool then thanksThat part will slide back together with out any problems... Why do you think its broken?
I'll assume I have to remove that to put the hub block on. I have that vid.There are some videos that are pinned at the top. One is about removing the diffs. Watch that one.
I still don't see a broken composite slider shaft. Maybe I'm missing something
Just the hub ??I still don't see a broken composite slider shaft. Maybe I'm missing something
