Infraction Infraction with limitless rear wing
Mdgaming
  1. Limitless
  3. Mojave
Recently I've been thinking what an infraction with a limitless wing would look like and I think it would be pretty cool.
Now I know the rear wing of the limitless can be bolted onto the infraction but I'm not sure which parts I'd need for that. Can someone help me out here?
Should be everything.
Main Wing Parts:
ARA480025 - Front/Rear wings (You'll only use the rear)
ARA320524 - Wing mount set
ARA320525 - Wing End Plates
ARA320526 - Wing Mount Plates
You will probably need to purchase the screws used with this set up separately as well. I snagged a couple of the screw part numbers then seen it was just easier to screen capture and underline all the part numbers for the screw needed.
Not pictured:
ARA727308
ARA721310
Rest will be in the picture
Hope this is some help for ya! Good Luck!
This is a great example of how it will look
Awesome work from James
I priced all the parts once before, and then abandoned the idea as it was just too much to justify for me..
If you got the parts from Jenny's or had a Limitless already that's another story..??
( Note to self ?, go buy a Limitless for spares..??? )
Main Wing Parts:
Not pictured:
ARA727308
ARA721310
Oh that's great, thanks dude
