Mojave Irritated...
The_Otherside
Huh?
Military Veteran
Appleton, WI
  1. Mojave EXB
Bought a motor mount for "large pinions" and "for castle motors"...
Asked for a refund.
Unless I'm missing something?
Its even from the same seller.
Not even the 25t pinion I had on the STOCK motor mount fits.
They accept returns, so that's cool.
But I mauled my stock mount trying to get the old pinion off 😑
1717 1650kv.
Idk what size it is other than that :(
looks like 4785, a stock mount is fine
my 4985 fits fine
I run that mount on my stretched 8s mojave with the hw 5687 1100kv motor
my 4985 fits fine
Damn dude. That top picture is frickin nasty!! I need mine looking like that!!
I'm not familiar with mounts, really. Do you have a link?
My dual battery stretch job is running the mount you bought. My other mojaves run the stock mount. You can put a 50 series motor plate on it if it is close to the chassis but you might have to shorten one of the slider screws that secures it in the slide. https://www.amainhobbies.com/arrma-...-mount-plate-red-ara320538/p-qqzktaeqncqxactz
This is my other one, running a hobbystar 4092 on the stock mount and plate.
Thanks guys.
The problem I had was I couldn't slide the motor out far enough for the 25t, so I grinded the slot a little longer.
Now the 30t pinion I have to grind even more and I think I'd end up compromising the integrity of the mount.
Will what you're showing me help with that?
