Was mainly gonna do speed runs and the ocacinal off roadDepends what type of conditions your driving it in. Out of the box the Krston can't take a lot of punishment.
New Chassis braces are a good upgrade if you do big jumps, the stock pinion will strip shortly (I'd start there), wheels aren't great but depends on terrain you are driving in.
What brands are good and can u link plz
I got the other spur gear that cam with the kit and tools would that be the same (garbage).
Can the stock ESC handle that servo, or do you need a higher amp BEC?First thing to replaced is your servo. Link below is insanely strong.
http://www.rcmart.com/blue-bird-bls...ss-digital-servo-p-67626.html?cPath=1099_1030
Sealed bearings should be on the list. If you aren't planning on jumping, the stock braces should be fine, and keep the weight down. Lots of speed run threads you can follow here. Center spool is a big help in speed runs. The stock servo will be fine if you set your end points correctly and keep it mostly on road. Most servos have a 6V and 7.2V spec, so you can run off the stock esc, with the lower speed and torque of the two values. There's a few servos that run at 6V that will give you slightly better results than the stock unit. Search the forum on threads that cover some of those options.Looking to see what upgrades to do on my new arrma kraton blx 6s
I hope he is still around to heed your advice ?Sealed bearings should be on the list. If you aren't planning on jumping, the stock braces should be fine, and keep the weight down. Lots of speed run threads you can follow here. Center spool is a big help in speed runs. The stock servo will be fine if you set your end points correctly and keep it mostly on road. Most servos have a 6V and 7.2V spec, so you can run off the stock esc, with the lower speed and torque of the two values. There's a few servos that run at 6V that will give you slightly better results than the stock unit. Search the forum on threads that cover some of those options.
The FastEddy set for the Kraton have everything that’s needed?Sealed bearings should be on the list.
I didn’t even notice that... ?The OP's post was from over a year ago ?
It does, including for small bearings to replace bushings in the steering posts.The FastEddy set for the Kraton have everything that’s needed?
Sometimes it takes an old post to find a new answer. @DaedalEVE is obviously doing some good searching, and for me, well this is what happens when I log in before finishing my first cup of coffee in the morning?I didn’t even notice that... ?
