So I've gotten about 10-12 packs through my k8s EXB. Setup is as follows, Max5, spektrum 1100kv 5687. Ive tried multiple different gearing setups now and have gotten the following results. Outside temp from 80F-95F, running in cut grass with 1 server fan on the motor, one on the ESC.
Pinion/Spur
1.30/39-Stock Tires-Ran great till it got too hot, motor hit around 200 so I figured I needed to take it easy or adjust gearing for the 1100
2.30/47-Stock Tires-Went from one extreme to the other, motors temps were much better but was still getting too hot for my taste.
3. 30/39-Duratraxx Six packs-Temps were much more acceptable but still to hot for me.
4. 27/39-Stock Tires-Motor was hot and ESC went into thermal protection mode.
To be honest I think I like the way the truck drives much better with the belted six packs than I do with the stock tires, plus it seems to be less strain on everything, electronics AND Drivetrain. The stock tires just make it feel clunky.
Am I that far off with my gearing??? Or is it really all the grass causing the overheating, like I said I'm not running in crazy high grass. Ill try to attach a video of where I run.
One more thing... the rear diff with the stock plastic cup likes to loosen itself up and eat the gasket every handful of packs or so. So this time I replace the cup and gasket, and jammed some m4 screws into it. It was snug but the plastic seemed to take it just fine as long the holes don't have any fluid in them. Will report back...
I have a O8S EXB thats brand new with another max5/5687 that I haven't even run yet because I think I'm partial to the long wheel base.
Pinion/Spur
