If I’m correct the stock servo is a 23tLook on Amazon and get something with lots of good reviews. There is a 35kg for $35, I have that one in my notorious.
You'll also need a new servo horn with the correct nr of spines. Spektrum decided they wanted to be special and have a bespoke nr of splines.
YesIf I’m correct the stock servo is a 23t
Thanks! So do I use a 25t servo saver Like that kimbrough with that 35kg servo, and then work on my driving technique? Is a servo saver a "must have" or can you set your steering endpoints carefully and just use linkage, the "servo horn"?Also, slop, the servo saver and a weak servo all contribute to less steering angle
That servo comes with an aluminium servo horn, but I don't know if it fits the ARRMA 4s range. I had to get a new one because it wasn't tall enough for my 6s Notorious. If it doesn't fit, just order another aluminium 25T servo horn, and see if that fits better.I saw on another thread that the servo you mention gets good talk on here as well as Amazon, probably order one of those as soon as I figure out what I need to go from 23t to 25 t.
If you want sharper steering at high speeds, let off the gas/brake lightly when you want to steer. This pushes the front wheels down.and then work on my driving technique?
Most RC cars have one stock, but they are very loose. They save the servo (hence the name) by absorbing the shock, but if they are to weak (which they are), they stop the wheels from steering if they're blocked. Usually, a tighter spring should be all you need to tighten up the steering.Is a servo saver a "must have" or can you set your steering endpoints carefully and just use linkage, the "servo horn"?
It’s a 23 tooth servo horn, yes? Who sells those?Look on Amazon and get something with lots of good reviews. There is a 35kg for $35, I have that one in my notorious.
Stock has 23t, but almost every aftermarket servo has 25t. Just look up servo horn on AZ, almost every one will be 25t.It’s a 23 tooth servo horn, yes? Who sells those?
