Kraton 4s v2
laro 1974
Brand new Kraton 4 s it has not run right since I got it last week it runs hard then slows down like the battery is dying.I check the voltage I got 3.8 amps let it set for couple minutes does same thing again I’m using gen ace 5000 mah 4s battery it’s brand got it with the car I don’t know what else to do can you guys help
Are you seeing 3.8volts per cell (all cells match?).
Do you have another battery you can try?
I am guessing your Battery is not so good.
After Low Voltage Cutoff (LVC) your batteries should measure around 3.6 volts per cell. If your battery is not healthy it will sag more under load and trip LVC showing a higher resting voltage after cutoff.
If one cell is going bad that can cause this too, the voltage of the bad cell will drop rapidly causing cutoff.
I would try another battery.
I don't think that ESC supports 2S.
