SrC
RC is a lifestyle choice
Hospitality Award
- Location
- Queens, NYC
- Fireteam
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Typhon TLR
Tight gear mesh, yeah. Very first thing to look at. If the case, highly suggest a motor tear down and inspect and lube. Preventative maintenance, especially if she was hot
But a larger pinion may be in order as well. If you have one handy test out the temps with it. Does your ESC have Data logging??? check the RPMs if possible. I am not familiar with that ESC. I know my sensored HW XR8+ has data logging.
The stock Arrma pinions are not all that BTW. I have had some duds. excessive wear with minimal use. FWIW. I like Tekno Pinions. Saga as well. But I use whatever...the smaller Stock ones seem to get trashed quick IMHO.
Hard to say if the pinion was too tight by this picture. Perhaps so. Wear does looks deep into the pitch. ? But the pinion was not centered well enough to the Spur. That is clearly visible. The center diff may also need to be shimmed so the spur wont slide left to right under load at the pinion. There may be some backlash in the Diff mounts. (Slop). I sometimes shim mine to the left or right depending, to get good pinion/spur alignment while shimming.Found something interesting when I pulled off the 16 Tooth pinion gear. The teeth are like worn and melted after like 30 total minutes of running. Something's gotta be funky with my setup. I've never seen a pinion gear have wear/damage like this.
