I just Disassembled the rear diff on my Kraton 6SEXB and I’m noticing that it doesn’t have the round disc on one side but it does on the other. Is this normal because my front and center diff had one on each side behind the sun gears
Check behind the gear.I just Disassembled the rear diff on my Kraton 6SEXB and I’m noticing that it doesn’t have the round disc on one side but it does on the other. Is this normal because my front and center diff had one on each side behind the sun gears
It’s not there I already didCheck behind the gear.
Okay, sounds like a factory defect then.It’s not there I already did
I contacted Tower hobbies and asked for a replacement, we will see what happensOkay, sounds like a factory defect then.
I had both of the round ones missing on my MEXB and made a claim a got sent a whole diff ( I later found the two LSD shims behind the gears, but the new diff fixed my diff problems ).I contacted Tower hobbies and asked for a replacement, we will see what happens
I recall reading somewhere that Arrma switched out the rear LSD diffs to open at some point so some versions of the 6s vehicles have LSD and some don't.Would like to revisit this as the exploded view is somewhat ambiguous and not being clarified by me opening the diff. Per the exploded view, I should have an additional ARA709059 washer in the rear diff somewhere? Didn't see one when I tore apart the rear diff. Is that missing? Also, why does the view say that LSD plates are only for the center and front? Yet I have them in the rear diff..?
View attachment 268374View attachment 268375
I just reassembled the F/R diffs tonight and when both are LSD, so that solves my problem! Could have swore I had fewer parts in the rear. The diagrams are confusing for sure though.I recall reading somewhere that Arrma switched out the rear LSD diffs to open at some point so some versions of the 6s vehicles have LSD and some don't.
