plastic stock fans don't last long. your better of getting a aluminium one they spin much fasterfew days ago i bought kraotn 6s exb rtr, every thing is working but motor fan is not spinning, just not working. Is it gonna turn on when it heat up or what?
The fan will spin all the time. As others have suggested already, check your connections back to the ESC. The fan can be warrantied but probably not worth it.... the replacement would likely not last either and a metal upgrade is cheap.few days ago i bought kraotn 6s exb rtr, every thing is working but motor fan is not spinning, just not working. Is it gonna turn on when it heat up or what?
It could be plugged in backwards. That fan don’t do much anyway. Run that thing and order an aluminum one from Amain, Amazon, Tower hobbies, Ebay etc.. be sure to get the right size. I think they are 35mm but ain’t sure. Make sure it has the right plug on it too.few days ago i bought kraotn 6s exb rtr, every thing is working but motor fan is not spinning, just not working. Is it gonna turn on when it heat up or what?
If all else fails, take the motor out and look at the motor bearings...hoping it was not running in water and the bearing seized up or the motor internals were not bad.few days ago i bought kraotn 6s exb rtr, every thing is working but motor fan is not spinning, just not working. Is it gonna turn on when it heat up or what?
