Yes, different braces between them. Body mounts depends on what you want. Kraton 6s body with extended rear mounts, or custom body from a different line altogether.. from physical dimensions, an Outcast 8s body should fit. All will require some creativity for mounts. Plenty of info here on the forum.What about body mounts and chassis braces? Do I need different ones that what the Kration has?
Think KnowAir got you fixed up. I did the same but Talion to an XL so I needed same/similar partsI Need help, I’ve found plenty of info but am looking for a definitive parts list to convert my Kraton to long wheelbase, based on Mojave 6S chassis.
