What shock oil do people recommend for a Kraton 6s (for big jumps and racing) the stock shock cracked and all the oil spilled outView attachment 341400
The piston nut probably just came loose. If your lucky you could just reassemble it and put the stock 80wt back in. Also big jumps and racing are going to have very different shock setups. Stock is a pretty good middle ground.
