I put down the game controller and picked up a ARRMA Kraton 8's and love it
Kraton V1.5 EXB Chassis
Skyfly GT5
HobbyWing Max5
HobbyWing WiFi Express
HobbyWing 56113 800kv
EXB 56seires mount
34pinion39spur
Alza Racing Twin fan mount
M2C Front Hinge pin sets
M2C Shock Pistons (slots down)
M2C Shock Shaft
M2C HobbyWing Max5 mount
GPM Rear Hinge pin set
GPM Stearing block
GPM Aluminum Differential Case front/ rear
Vitavon Front & Rear Hubs
Ceramic bearing inside parts only
M2C Retainers only
Scorched RC Outer Driveshafts
Scorched RC Pillow Balls
JX Servo 60kg 1/5 scale
Sway bars 5lbs rear 4lbs front
4 DIY Fans 40x40x20 on 3s
Differential fluid
Front half 300,000 half 100,000
Center 20 million plugs
Rear 500,000 (may mix 300&100)
30wt Shock oil Front
35wt Shock oil Rear
Carbon fiber rod 4mm in the center of the tower braces
Carbon fiber tube on outside of tower braces
So far that's it and it's been a blast
Skyfly GT5
HobbyWing Max5
EXB 56seires mount
34pinion39spur
M2C Shock Shaft
GPM Stearing block
M2C Retainers only
Differential fluid
35wt Shock oil Rear
