EAGLELITE
im in the process of doing my shocks....the manual says the kraton uses 1000 cst oil,,,,,weight,,which seems kind of heavy. I was under the impresoon that 30 wt was the stock oil.....I want to stiffen the suspension a little. I don’t bash that hard just want a good ride for general use. Team associated oil says 1000 cst is 80wt. Is this going to stiffen the ride to much? What do you suggest is a good middle of the road shock oil.......I kinda want to keep the stock springs if possible. Thanks guys.....
