m.mahdi_sh
- Granite
hey there
finally i got a granite V3 Blx as my first rc and i've got some soldering to do so i thought i should check on the gear mesh and the slipper clutch as i've read some had problems with them out of the box.
i took out the power module, unscrewed the case, the mesh was a little tight so i loosened it a bit and screwed the case back on. but then i noticed some play in the spur going back and forth.
i don't remember if it was loose out of the box and i'm pretty sure it wasn't like this.
so my question is
should the spur-clutch assembly have this type of play? or i'm missing smth here?
tnx for the help in advance
P.S: the motor screws where so tighten from the factory, the screws had a print on the motor plate!!
so my question is
