It didn't take long for my original body to get pretty mucked up due to the rear wing getting wedged into the tailgate area after a rough landing or cartwheel. Here is my solution.
1. Purchase the following (I got these from Home Depot. I am sure any good hardware store has similar items.):
4 - 1/2" x 1/2" x .194 Nylon spacers
4 - M4-0.7 x 45mm screws (you may be able to get away with 40mm, as mine stick out a bit past the shock tower)
4 - #8 x 1/4 " od x 3/4" aluminum spacers
You can re-use the lock nuts that already come on the Outcast or get new ones. M4-0.7mm
2. Drill out the center of the nylon spacers about 1/4" deep on one side with a 5/16" drill bit. On the other side, drill out the rest of the center with a 1/4" drill bit.
3. Place the aluminum spacers into the 1/4" opening. See picture.
4. Drill out the rear wing mounting holes on the rear shock tower with 1/4" drill bit.
5. Place nylon spacers into new holes, aluminum end first. See picture.
6. Mount rear wing as you normally would, using new spacers and longer screws. Here is the final product. I can't be 100% positive, as I already cut out most of the damaged section of the body, but I do believe this will help reduce/eliminate the issue of the rear wing getting wedged into the body.
