Typhon my new typhon 3s
slick
is there anyway to test the servo the unit has forward and reverse,just will not steer.will this fit in there
The 25kg version would make a lot more sense. Keep in mind the stock servo is like 6 or 7kg. 25kg is more than enough torque but by going higher torque, you will be trading away speed for torque you do not need. I have 25kg brushless 9imod servos on all of my Arrma 3s cars and they are excellent. If you use the 25 tooth arrma servo saver, it won't allow you to apply more than about 10kg of torque anyway before the spring is engaged.
