K8S EXB roller: with Ezrun MAX5 800Kv 56113 motor. I did watch the instruction video here (
Spektrum DX3 with SR315.
However, after binding I can NOT calibrate which means it acts like it is bound and ready (throttle and steering work but NO AVC). To be exact, after I turned on the RX, press bind button, RX led flashed, turned on RX in bind, the RX led stopped flashing but it didn't go into calibration mode (if I then moved the throttle, the motor would turn and the steering worked too). At this ponit the throttle should be disabled and once I pull trigger to full, the led should go out and then back on. But in my case, the RX led is always solid.
Next I reset the TX and tried to bind it to the RX again to no avail.
I did start trying to bind with AVC disable by power on the RX and press 3 plus 1 time hold, so the led flashed ready to bind but I didn't go through with that which I tested to confirm that I did NOT disable the AVC.
Any thought?
Thanks,
Any thought?
Thanks,
