pierre1111
Complete rookie… just got my first truck, a kraton 4s v2 rtr - came with a slt3 and sr315 receiver. May have been too much for a first truck but I wanted something with a bunch of suspension travel
The throttle seems really touchy even with the 50% limit set. I did calibrate it. Maybe I’m just not used to it yet but it feels difficult to drive around slow, the throttle is touchy. This is with a 3s battery too.
Second - reverse has an odd behavior. In my effort to go slow im slowly moving the lever. I found when move slow enough in reverse I can go all the way to the limit and nothing happens. If I go full reverse quickly it goes back just fine but if I creep up to max reverse slow enough it will not move at all. Is that normal ?
Also - if I set the reverse throttle switch it does the same thing. The throttle lever reverses direction as it should, however reverse is the same. If I slowly creep up on it and hit the end, the motor doesn’t turn at all.
Assuming it’s not normal behaviour, I’m leaning towards a remote issue.
