- Statesville nc
- BigRock 4x4
- Kraton 6s
- Kraton 4s
- Outcast 6s
- Talion
- Typhon 3s
- Thread starter
- #21
Traded it for my left nut
I had the same issue. Cranked the clutch down and beast mode. Now the slow steering servo is very noticeable.Slipper was 5 turns to loose.
The 4s shafts should be longer because the arms are longer.Ok it will wheelie like hell. Slipper was 5 turns to loose. Next prob blew out left rear driveshaft. Will 3s shafts fit 4s?
And the punch going back to lvl 3 ?
of course it wheelies on command!! It’s RICH DUPERBASH hahahaI saw @Rich Duperbash take his new 4s Kraton out for a spin, and wheelies weren't a problem. Even while moving, he was popping them up pretty easy. Watch around the 9:30 mark in the video.
Batteries are everything. Look more into that brands specs, or specifically someone that has actually tested them to see if they are producing the punch they should be. Might just be a weak packSo waited forever for my new 4 s kraton. It won't wheelie. Turned in slipper clutch till tight then backed off 3/4 turn and turned punch to lvl 4. And still won't wheelie. Fast as hell but I wanna wheelie. Running to 6500 ovanics 50c 2s. Driving me crazy. ?
And how tight is tight on slipper clutch. I turned it in 3 turns from factory. So I thought just loose from factory. Got it tight but didn't wrench on it
