Slim1990
I recently got a SMC 5400mah 2s battery. The first charge was showing my Hitec charger put 4839mah back into the battery, which would be around 90% capacity. My volts were right around 3.68 (+\-0.01)after pulling the battery out of the truck. Did the battery take that much charge due to being new or should I set my low voltage alarm higher to keep battery voltage higher. I had the alarm set for 3.7. When using 3.7 with my dynamite 5000mah 2s, the cells are around 3.75 after pulling battery from the truck.
