rccar4life
- Limitless
- Kraton 8S
- Kraton EXB
- Mojave EXB
- Talion
- Typhon TLR
easy mount to 42 size motors
Now available from Powerhobby is a 1/8 Aluminum HeatSink Turbo High-Speed 30mm Fan w/ LED Lighting. To help reduce the heat on that 1/8th motor of yours, the new unit from Powerhobby uses a high-speed 30mm fan, plus a large aluminum heatsink. Here are the highlights-
* Available in 4 colors
* Fits motors with a 42mm diameter
* Easy to install
* Receiver plug is used for power
* Input Voltage – 5 to 8.4 volts DC
* Heatsink made from aluminum
* Colorful LED light flashes slowly
The Powerhobby HeatSink Turbo High-Speed 30mm Fan w/ LEDs has a part number of #PHT1299 and is street priced at $22.
https://www.bigsquidrc.com/powerhobby-1-8-aluminum-heatsink-turbo-high-speed-30mm-fan-w-leds/
* Easy to install
