Limitless Newest on Road Addition
-IronMan-
Still waiting on a few more parts but all the main stuff has finally arrived
What TP motor is that? I've debating almost the exact same power system.
As others have suggested to make it not such a missile in handling get a center diff and gear down a little... unless you are chasing them speeds. :cool:
I’m doing a speed build it’s 4050 2300kv CM motor. Still waiting on the servo and receiver for this.
Nice. I haven't done the maths yet.... but I want to get something around there and only then only run on 4s. With reduced gearing. If I run 6s my ESC will fry(MM2). Already un-soldered deans connectors on first run. XT90's on the next, unsoldered the ESC power wire ?
THEN once I upgrade my ESC, back to the spool diff and tall gearing.
I ordered some ose 8mm anti spark connectors and 8mm bullets for the setup. The setup I’m doing is 8s. I’m going to reduce gearing to start just so I can get used to it. Then gear up gradually.
