Thanks Steve, I have the combo box for the bigger servo already Just can't deal with stock servo...drives me nuts. LOLPrimal RC 1373 servo. Many go with these.....The stocker is a lame undersized 1/6 servo. You need a True 1/5 scale servo. You are not alone.
Will need to use the Arrma Optional Rx box kit which allows for this larger servo. I think this is included with the EXB roller kits. Not with the RTR kits. FWIW.
Good luck.
I have 4mm sway bars for Outcast 8s.5mm/4mm swaybays is huge for handling.
I snagged a couple 5's5 in the rear 4 in the front is what I run.
I find that in general, you use thinner Sway bars at the rear end compared to the front. A good place to start,I have 4mm sway bars for Outcast 8s.
Not mounted yet.
Should I get some 5's?
I have both 4 and 5 now.I find that in general, you use thinner Sway bars at the rear end compared to the front. A good place to start,
Good to have both sizes, because it is trial and error to dial them in best.
Some even elect to not use any at the rear. One at the front can usually will do the trick. But this is a track level decision for technical driving. With bashing in the wide open, 2 Sway Bars usually work best. Thinner bar at the rear.
