The BRCC might be too long for the Ambush body.Looks good. You got a part number? I want to look at the dimensions. I want to get the Ambush body for the MT4x4 for my BRCC.
This looks sweet - can you upload pics of the finished job when ready?!Got a bit more trimming to do and will probably.paint it white/ black stormtrooper style. Had to use to the mounts from senton bit overalI am very happy.
yeah the baja body is nice but is still on the smaller side over all i know the BRCC is longer so with the engine you might have clearance issues at the back. I ended up having to cut the motor off my body due to it causing damage once the rear wheelie bar broke...lolI just wanted to check the specs on the baja body against the Ambush body and the Raptor Body 3345-00 I used for my BRCC. The Ambush wheelbase is 10.8" and def won't fit the BRCC.
While the SCT bodies match the wheelbase for the BRCC, there is no way to clear the wheels and tires(they barely clear SCT tires). Looks like the Proline Bodies for T-Maxx 3.3 and Revo 3.3 are best options right now. I had to trim out a lot of wheel well to clear the badlands, but it works.View attachment 26269
So I guess that means there was never a good permanent fix?Sure can, might be a bit as the rear got damaged by the mounting point. so i'm waiting for a new one
