Qs8 lipo charger?
I use the k2 air from isdt. Awesome charger. And just make my own leads with xt60 for input and solder whatever connector u need.
I use Rc battery liperior and cnhl
QS8 is just a connector type, any lipo charger should work - you need adapters that change whatever connectors your charger uses to QS8. Lots of good chargers out there, I personally use an ISDT K2 Air.
Sort of related, between the battery and charger is the only acceptable place for an adapter. Never use an adapter between the battery and esc, maybe for testing but never use under a load.
That’s what I meant, I see no chargers have qs8 plug
I use a ProTek and SkyRC charger.
https://www.amazon.com/gp/product/B01MZ1ZZ7Z/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amainhobbies.com/protek...v-lipo-ac-dc-battery-charger-ptk-8517/p488513
You can get whichever charging leads you need. Neither came with a QS8 set of leads.
The ProTek is pricey, but a whole lot faster.
Batteries are based on use. Speed run LiPo’s are expensive. I use Zeee and other Amazon cheapo batteries for bashing.
SRD, Onyx, etc. for speed runs.
Thank you I appreciate the guidance brother
