Got a slight issue with the repaired diff in my Mojave. I was the guy that posted the carnage from my big wreck the other day.
Slight problem though, when I repaired the truck, I changed the rear diff fluid to 30k. Some guys have said it helps the handling.
However, when I tightened down the diff plate cap screws (the main 4 that hold the lid on), the diff got really tight and knotchy and didn't want to turn. When I loosen the screws, it spins fine, but fluid leaks out around the screws since they are loose. I used the little side thing to drain out some of the fluid, but it didn't really help. There's no shims except for 1 factory shim under the main end gears on each side.
Has anybody run into this before? Did I overfill the diff with too much fluid? Is my plastic diff case just toast?
