Drove my non-diff brain Nero for the first time today and did some jumps and just general bashing. Love the way it drove and handled on the ground. Once I get the bugs worked out and learn all the ins and outs, I think it will be my go to bash Truck. I did end up breaking 2 rocker posts and the steering rod screw just fell out. Luckily I was able to find the steering arm screw and the nut was still where it was supposed to be. The rocker posts need to be replaced however because they snapped. 2 questions:
1. Air control. When in the air, hitting the brakes does what it should, lowers the front. But applying throttle while in the air does nothing. Is this because of the center diff not applying enough power to the rear? Couldn't even do a wheelie. What else could be the culprit? Was running 2s batteries but before anyone blames the 2s, I can do standing back flips with my savage flux with the same batteries with great air control too. Thinking it must have something to do with the center diff on the nero. If so, would sealing the diff and adding some 500k fluid help you think?
2. Rocker post. Is there a fix for this? Breaking two in a single easy going bash is concerning to me. I did a search and one guy went to home Depot and bought some stainless screws. Another guy converted his posts to e-revo. Is there a better solution or is one of those 2 solutions better than the other? I have a home depot 5 minutes away so may try that one unless there is a better solution.
For reference, today's run was in stock form running stock pinion and 2s SMC 9000 batteries.
Thanks in advance for your help
