Kraton Screw in the motor
JaviKraton
Hello mates, today my kraton 6s v5 start a loud pinion sound , i check it and one screw in the motor is exit 😂( i post a photo) arrma fast arrma tough 😂😂
I have a question: i only screw this screw? The gear mesh will be the same?
I need to put a paper for good gear mesh?
Thanks mates, i appreciate ur comments!
That screw will not have an effect on the gear mesh it just holds the motor to the motor plate. The 2 screws on top of the motor plate allow you to make adjustments to the gear mesh.
Before you tighten it up but take it fully out first and clean it, then apply a small amount of LocTite (I use blue) and tighten. Check the mesh and adjust as necessary. If you do end up adjusting the mesh get some cap head hex screws and washers in the same size as the button heads that you have installed and swap them out. They are less likely to strip.
Thanks!!! This is the info i wish see 😂, that screws you comment i think the allen key stripped that screws for sure 🥲 the allen key dance so much 😂 i don't touch that screws yet, i go to screw the screw in the photo only , really thanks mate!
thanks!! I don't want touch those screws for this reason i think that stripped easily , i go to screw the screw in the photo only
Oh yeah on the motor mount on my Fireteam I hit them things with a torch for like a minute and they still stripped out.
