Sea Fury
Hey guys, been awhile!
I now live in SC low country 2miles from an active MCAS so no RC flying anywhere near me.
So, I got back into cars!
Been running my Kraton 6S having fun!
Then I bought 2 more trucks so my cousins can play with me.
A used Senton 3s BLX (Garbage buy, rocks bind steering constantly already had to replace steering servo and now BLX ESC is fried!)
Also bought a brand-new Big Rock, it's ok but I realize now it was a waste of money as it's just a Senton with longer Arms lmao.
Anyway, my K6 started making awful screaming noises when I hit the throttle.
To many back flips off my BMX ramps, then I found a big skate park and really beat the crap out of it.
Barely moves now.
I took the rear diff apart, it's fine.
Took the center diff apart, it's fine.....noticed my pinion gear is worn, but not gone by any means.
Decided not to mess with the front diff.
After playing with it near my feet without the body and watching the motor pinion and pinning it down while I hit the gas, I see its stripped even though it still has teeth.
The center diff Spur seems fine but going to grab a spare anyway.
Problem is, those 2 bolts on top of the motor mount, looks like that's the slide mechanism to adjust gear lash, well one of those pos stripped when I tried to loosen it!!!!!
Now that I KNOW for a FACT my pinion is trash, I need to get this motor off to replace it, and tighten the gear lash obviously.
Any ideas on how I can get this stripped pos bolt off so I can fix my baby?
I am thinking I need to get a Dremel cut off wheel and slot the head then heat the whole mount and try it with a flat head screwdriver?
I also thought about drilling the head off, but I don't see how I would ever get the bolt shaft out of this aluminum plate doing that to be able to replace it?
Any better ideas considering what a pita that's going to be with my new living situation and 99% of my tools packed away in my trailer?
And no, I don't want to be buy a new motor mount, motor, and pinion lol.
Please help!
Also, am I the only one that constantly snaps the 2 rear entry bolts to the wing mount, that go into the diff housing?
Every single time I replace them, on the next battery, one bad landing on the wing, snapo!
So tired of that one issue as the wing mount is tied into my fancy EXB chassis brace so when its broken it compromises the entire thing.
Barely moves now.
Please help!
